Activity Forums Media 100 Can’t export from edit suite? What do I need to do?
  • Can’t export from edit suite? What do I need to do?
    Posted by Jerome Robbins on November 26, 2005 at 1:49 am
    From an earlier post, I had some clips that had been digitized at a 60 instead of 300 quality. I redigitized all the original clips into a bin at 300. I replaced all the lower quality clips with the new ones. This was an all day fix.
    Now, I went to Export from the edit suite ,as I want to export the program as a QT movie for authoring in DVD Studio Pro. The Export from Edit Suite is grayed out and not avaliable as an option.
    What could be causing this and what can I do to fix it? This project is stopping me at every turn.
    Thanks for continues help,
    Jerome
    Floh Peters replied 20 years, 10 months ago 2 Members · 1 Reply
  • Floh Peters
    November 26, 2005 at 6:50 am
    Open the “Monitor” or the Source & Record window. It can happen that Export from Edit suite is greyed out if the Recod window is not opened.
