Activity Forums Apple Final Cut Pro Legacy cant enable video playback on m10u
  • cant enable video playback on m10u
    Posted by Cade Muhlig on June 28, 2006 at 1:01 am
    ok so i have a m10u connected to my mac through firewire, and i can import just fine, but i want to playback through the m10u then component to a tv for color correction and such. i remeber a while back i was able to do this, but now when i go to video playback > it give me HDV ( 1440 x 1080 ) 30 fps or 25 fps, or just the desktop.
    cade
    Cade Muhlig replied 20 years, 2 months ago 2 Members · 3 Replies
  • Cade Muhlig
    June 28, 2006 at 1:11 am
    opps, i forgot to mention that those two oprtions (not desktop) are greyd out
  • Andy Mees
    June 28, 2006 at 10:36 pm
    if you are editing in DV then you should be able to use the workflow you’re suggesting … but not for HDV. are you using HDV? there is no capacity to play HDV over firewire from the timeline whilst editing (you need to conform your edit before you can do this)
  • Cade Muhlig
    June 29, 2006 at 7:31 pm
    why not? i can import hdv from a dv tape and i can export hdv to a tape, but i cant preview hdv on the tape deck? thats lame
