Activity Forums Adobe After Effects Can’t edit keyframes in After Effects CC
  • Can’t edit keyframes in After Effects CC
    Posted by Milton Whitaker on May 8, 2014 at 2:33 pm
    Hey guys,
    I’ve been using CC for quite some time now without a hitch. Today I’ve run into a problem I’ve never seen: I am totally unable to edit keyframes (meaning right-click and adjust keyframe interpolation, toggle keyframe hold, etc) and it is only in one particular comp. I’ve tried deleting my preferences but other than that, I can’t seem to figure out where the problem is coming from nor how to go about fixing it. Any input would be greatly appreciated!
    MJ Whitaker
    Motion Designer / Visual FX Artist
    Mazyar Sharifian replied 12 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Milton Whitaker
    May 8, 2014 at 2:38 pm
    Also, I should add that I tried creating a new comp and copying and pasting the layers into it, but when I select all of the layers i get an error saying:
    After Effects can’t continue: an input contract violation has occurred
    Thoughts?
    MJ Whitaker
  • Roland R. kahlenberg
    May 8, 2014 at 2:39 pm
    Did you inadvertently lock the layer with keyframes?
    HTH
    RoRK
    Gaudy Teaser Promo for an upcoming AE Type Gizmo.
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
  • Todd Kopriva
    May 8, 2014 at 3:19 pm
    That message is typically because of a badly written third-party plug-in. Are you using any third-party effects in this composition?
    After Effects team blog
  • Milton Whitaker
    May 8, 2014 at 3:32 pm
    The only 3rd party plugin used is Particular, which is precomped and turned off. Also nothing is locked. I also forgot to mention that I can’t select any keyframes directly by clicking, I have to drag select them. And even then, I can’t move them or make any modifications. I can however access all keyframe interpolation controls through the Animation menu but just not directly. On the other hand, when I add new layers to the comp I can adjust the keyframes however I want with no problems.
    MJ Whitaker
    May 8, 2014 at 10:24 pm
    As Todd’s suggested, it’s very likely a plugin issue. What are the effects you’ve applied to the problem layers?
    HTH
    RoRK
  • Todd Kopriva
    May 9, 2014 at 3:46 am
    Were the keyframes created in a composition that then had its framerate changed?
  • Mazyar Sharifian
    August 21, 2014 at 7:04 am
    I ran into the same problem and I realized that it is due to framerate change.
    I had a text layer in a 25fps comp which was a subtitle for a feature film.
    Then the client requested a 24fps version of the subtitle for cinema premiere so I copied the text layer from 25fps comp to a new 24fps one.
    At first I didn’t have any problems, but later on, when I arrived at around 45 min, the mentioned problem happend.
    Solution:
    The solution is simple. Just create your layer from scratch in a comp with a correct framerate (In my case, a text layer in a 24fps comp), then copy the attributes (Effects and Keyframes) from the one which is locked to the new one and then replace the new one with the old one.
  • arthur costa
    January 22, 2021 at 1:27 am
    i am having the same issue, have you been able do solve it?
