Activity Forums Zaxwerks Can’t Edit Duplicate Comp Without Messing Up Original
  • Can’t Edit Duplicate Comp Without Messing Up Original
    Posted by Elizabeth Wallace on March 25, 2011 at 11:01 pm
    Hi All,
    I’ve got an AE problem. I pre-comped some footage inside of an HD video composition, creating two tracks in my timeline.
    Seemed straightforward enough. But when I went to delete some items from my duplicated pre-comp copy, it deleted them in my original as well! I want to create a copy of the comp that can stand on its own without being linked somehow to the original that it was duplicated from.
    How can I do that?
    Thanks so much!
    ~Elizabeth
    Andrew Devis replied 15 years, 6 months ago 2 Members · 1 Reply
  • Andrew Devis
    March 26, 2011 at 9:42 am
    I think you can get a script at aescripts.com to create a new project from a comp. If you did that then you would pull the new project into your current project as a new independent item.
    hope this helps
    Andrew
    … because it’s all about stories …
