Activity › Forums › Boris FX › can’t drag to container
  • can’t drag to container
    Posted by Axel Andy on February 23, 2010 at 11:04 am
    When I try dragging my tracks (tried text tracks & image tracks) to a container (either text containers or 3d containers) I get the “0 with a / (slash)” icon and Boris will not let me do this. I’ve tried doing 1 track at a time and that doesn’t work, either. I’ve tried highlighting the tracks and right clicking “convert to container” but it separates my text into 1 letter on each track. I’ve tried with the stand alone engine and through Avid but it still won’t let me. Should I delete my settings file(s?)
    …actually – I am unable to drag anytracks anywhere (even outside a container)
    K
    Matt Mullen replied 16 years, 7 months ago 3 Members · 4 Replies
  • Peter Mcauley
    February 23, 2010 at 2:12 pm
    Hi Kay,
    Sounds like the result of a preference file that needs to be deleted. If you are on a Mac, remove this file:
    MacintoshHD/Users/(LoginName)/Library/System Support/Boris RED 4.3™Preferences
    If you are on Windows, remove this file:
    c:\Windows\BorisRED4.3.ini
    Then just relaunch the RED Engine or the plug-in and a new default preference file will be generated by the application.
    Cheers,
    Peter.
  • Matt Mullen
    February 27, 2010 at 8:38 pm
    Axel,
    Did trashing the prefs help?
  • Axel Andy
    February 27, 2010 at 10:56 pm
    Sorry I didn’t get back right away…
    Actually – re-booting helped. Thank you!
    K
  • Matt Mullen
    March 1, 2010 at 1:11 am
    No worries.
    I just wanted to make sure you were all set.
    -Matt
