Activity Forums Adobe Premiere Pro Can’t drag clips to my timeline… It was working just a minute ago?!
  • Can’t drag clips to my timeline… It was working just a minute ago?!
    Posted by Christina Empedocles on July 19, 2016 at 4:34 am
    Hello wise Premiere Pro community,
    I am having a problem with not being able to drag or insert new clips onto my timeline I have a sequence selected. I have V1 and A1 selected, but none of the clips that I have in my project will stick in the time line. I get a hand crossed through circle. I am sure there’s some little thing checked or not checked that has made this happen, but I can’t find it anywhere. I checked all the tracks to make sure they aren’t locked… Any suggestions?
    I’d be so grateful if someone has an idea of how to clear this up.
    Very best,
    Christina
    Joe Edgin replied 7 years, 6 months ago 5 Members · 5 Replies
  • Jon Doughtie
    July 19, 2016 at 8:43 pm
    Christina, do you have V1 and A1 selected on both the source AND record columns of the patch panel?
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Ann Bens
    July 19, 2016 at 11:05 pm
    Most common user error is not source patching the tracks.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Christina Empedocles
    July 19, 2016 at 11:11 pm
    Ah! Ann, you’re amazing! Thank you so much for this super helpful explanation. I am so grateful — You saved my sanity!
  • Thomas Morter-laing
    July 20, 2016 at 6:13 am
    Make sure there’s no in and out set on time line.
    Right click next to the scrubber and clear in and out points.
    Tom Morter-Laing
    Twitter- @T_G_M_L
    _________________________________________________
    iMac 27\” intel i7 3.4GHz, 12GB RAM, ATI HD 6970M [2GB GDDR5], 3x G-Tech G-RAID (0) 2TB over Thunderbolt via Sonnet Echo Pro ExpressCard/34 Thunderbolt adapter and Tempo™ SATA Pro 6Gb ExpressCard/34.
  • Joe Edgin
    March 8, 2019 at 7:04 pm
    Old thread…but here’s a new thing to check if you experience this bump in Premiere Pro CC 2019. Probably a pretty basic fix for most pros, but it took this novice a little while to figure out. ????
    Take a look at how your keyframing is set up within the timeline. To do this, make sure your tracks are tall enough to see the “Show Keyframes” drop-down menu (outlined in image). Make sure it’s set to “Clip Keyframes” and not either track keyframe option.
    Ran into this problem myself and noticed I still had my tracks set to “Track Keyframes > Volume” as I had been working with audio mixing in a previous session, forgetting to reactivate Clip Keyframes. Switched this back over and voila.
