Activity › Forums › Apple Final Cut Pro Legacy › can’t drag audio file in FCP timeline
  • can’t drag audio file in FCP timeline
    Posted by Adam Chesbrough on October 7, 2011 at 7:30 pm
    I am attempting to click and drag an AIFF music file within my FCP3 timeline and it won’t let me. I click on the file within the time line and +(or-) frames and it will move but I can’t drag. I have trashed my prefs and still nothing. Never had this issue before. I have set up a ton of markers on the clip (to go with the beat…maybe that is the issue). Thanks
    macbook pro 17″ i7, 8GB RAM
    2 RAID 0 esata external HD 7200RPM
    Jenna Bush replied 13 years, 5 months ago 4 Members · 5 Replies
  • Steve Eisen
    October 7, 2011 at 7:57 pm
    Any in/out points set in your timeline? Do you have the audio patched to the audio tracks you want?
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Adam Chesbrough
    October 7, 2011 at 7:59 pm
    There were no in/out points on that clip and it’s a stand alone (not linked to any other clip). I just reimported and remarked the clip and it is working fine, strange issue though that I have never experienced. Thanks for the reply.
  • Joy Endicott
    January 6, 2012 at 11:10 pm
    I have a similar issue, but it’s not just the audio clips.
    I have an indexed media file, one video and 2 audio tracks, that will not move by dragging. When I try to drag I get a small yellow window that has xx:xx;xx in it and nothing happens.
    If I go to the “+” key and enter a value, the clip will move.
    If I drag up or down to a different track, the clip is deleted.
    If I use the blade and make a cut, the clips will move using drag.
    I tried a new sequence, and a new project with the media file copied to it and get the same results.
    The tracks are not locked.
    Any ideas?
    Using Final Cut Pro 7.0.3 on MacPro running OS X 10.6.8
    Thanks for any tips or clues!
  • Joy Endicott
    November 13, 2012 at 8:03 pm
    Anyone have any ideas on the problem here?
    It has happened again, and the clips with the issue are crashing FCP!
    Thanks for ANY help!
    Joy
  • Jenna Bush
    April 30, 2013 at 6:33 pm
    I had this same problem today. I ended up exporting the audio as a wave using quicktime conversion and then re-importing it into the sequence. This worked and the clip is now moving without issues.
