Activity Forums Apple Final Cut Pro Legacy Can’t drag and drop anything.
  • Can’t drag and drop anything.
    Posted by Jojo Castor on May 25, 2010 at 2:40 pm
    I just got final cut (express to start) and it’s my first day.
    I’m reading the manual and watching videos since this morning.
    Ok this morning I was trying to grab a transition from the browser to bring it into the timeline but nothing happened. Now I’m simply trying to drag a clip into a bin and nothing happens.
    Apparently I can’t just drag and drop.
    Could you please tell me why if you know?
    Thank you.
    Eric Spears replied 16 years ago 4 Members · 3 Replies
  • John Fishback
    May 25, 2010 at 4:05 pm
    Can you drag & drop in the Finder?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Alex Federman
    June 2, 2010 at 1:46 am
    Hi, I’m kind of having the same problem (in Final Cut Pro though).
    I can’t drag clips or effects/transitions from the browser panel for some reason. I can double click them to open them in the viewer, and then drag from the viewer to the timeline, but when I try to drag them somewhere, they don’t move. I can drag and drop in the finder. Thanks.
  • Eric Spears
    September 5, 2010 at 12:08 pm
    I had the same problem yesterday. The only way I could add an effect to a clip in the timeline was to click on the clip and then go to the drop down effects menu (as opposed to finding the effect in the effects pane/bin and dragging it over). But today, the problem has fixed itself.
    Now I have a new mystery problem: I can’t click on a transition! I put 2 clips together in the timeline & normally I can click at the point where they touch and then choose a transition, like cross-dissolve. But today, even after re-starting FCP, nothing happens when I try to click at the transition point. I’ve been using Final Cut Pro for over a decade and this has never happened before.
    FCP:6.0.6
    System: Late 2009 Power Mac, 2 X 2.26 GHz Quad-core Intel Xeon, 12 GB memory
