Activity › Forums › Adobe Premiere Pro › Can’t do Dolby DVD from PPro 2.0?
  • Can’t do Dolby DVD from PPro 2.0?
    Posted by Mark Weaver on March 6, 2006 at 5:08 pm
    Hi all,
    I just ran into this last night. It seems that the
    EXPORT to DVD from the PPro2.0 timeline is limited to
    MPEG and PWM unless you spend $295 for the encoder.
    This seems so strange, because if I have Encore(which I do)
    I can output Dolby Digital without having to purchase
    the encoder. I thought Premier Pro and Encore used
    the same code for DVD creation. I am not trying to
    do anything more that stero dolby.
    Anybody know anymore about this? Did I miss the option?
    Mark
    Steve Freebairn replied 20 years, 6 months ago 4 Members · 4 Replies
  • Rich O.
    March 6, 2006 at 5:36 pm
    Maybe they use the same code, but it appears dolby digital sound, provided by the Surcode plugin, is limited to 3 trial uses. I ran into this myself last night. It would be nice to have it included in Premiere, but plug-ins cost money, even in bulk. I’ll be going the extra step with Encore if I need the extra space that Dolby will save me over PCM, or if I have to get more sophisticated than Premiere allows me to easily do.
    Good luck
    Rich O.
  • Mark Weaver
    March 6, 2006 at 6:33 pm
    Rich,
    Yeah, your right, plugins do cost extra, but I was
    just under the impression that PPro and Encore shared
    this code, and since Encore can create Dolby Digital I
    thought it would work in PPro too. Oh well. If I have
    something small PCM will work fine.
    On to ENCORE 2.0(which should be fun to play with anyway)
    Mark
  • Victorypoint
    March 6, 2006 at 7:15 pm
    I’m pretty sure it’s not the same code. The Surcode plugin can create a Dolby Digital 5.1 mix whereas Encore can only create a stereo Dolby mix.
    -AJ
  • Steve Freebairn
    March 7, 2006 at 4:03 pm
    Has anyone tried copying the codec from encore to the premiere directory?
