Activity Forums Apple Final Cut Pro Can’t delete compound clips from the Event Browser
  • Can’t delete compound clips from the Event Browser
    Posted by Nick Harambee on November 2, 2013 at 9:59 pm
    I am unable to delete any compound clips from my event library. I see the following error:
    I am sure that these compound clips are not currently in use in any project, and I have restarted the application and still can’t delete them.
    What else can I try to get rid of them?
    Nick
    Doug Metz replied 8 years, 1 month ago 4 Members · 5 Replies
  • James Ewart
    November 3, 2013 at 2:08 pm
    I had this. I am fairly certain you will find a little bit of the compound clip in one of your project timelines if you look very carefully.
  • Nick Harambee
    November 3, 2013 at 3:36 pm
    Thanks. I’m sure the clips are not in use. I have now been led to believe this is a bug. I have hidden all of my projects and still can’t delete any clips from events.
  • James Ewart
    November 3, 2013 at 6:14 pm
    All I can say is I had the exact same problem and it drove me nuts and I found one frame from a compound clip in one of my timelines.
    May well be different for you.
    what would be useful would be a shortcut “reveal in project timeline”
  • Eric Suntken
    August 2, 2018 at 7:43 pm
    Thanks so much, James. This was driving me crazy because I was sure the clip was not in use. However, when I zoomed into my storyline as much as it would allow, I found a frame from the clip that was previously undetectable. I appreciate your help!
  • Doug Metz
    August 3, 2018 at 2:00 pm
    [James Ewart] “what would be useful would be a shortcut “reveal in project timeline””
    +1
    If Final Cut knows that a clip in use somewhere in a particular Library (even if it isn’t in the active Project), it should be possible to identify which Projects are using the clip.
    Sending feedback now.
    Doug Metz
    Anode
