Activity Forums Maxon Cinema 4D can’t create rigid body
  • can’t create rigid body
    Posted by Ong Joseph on January 7, 2011 at 4:58 am
    need help…is there a limit to the trial version of Cinema 4d 12. I can’t seem to get the dynamics to function. The dynamics body tag is always on the collider symbol, can’t get the rigid body although i applied it from the dropdown menu.
    Adam Trachtenberg replied 15 years, 7 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 7, 2011 at 3:03 pm
    I think the demo is save enabled for 30 days but other than that it should keep functioning indefinitly. Not sure what you mean about the dynamics tag. When you look at the Dynamics tab in the attributes manager there’s a parameter called “Dynamic”. If should be set to On and the enabled box should be checked. Then it should work.
