Activity Forums Adobe After Effects cant create Image Buffer error – AE CS4 and Latest Mac
  • cant create Image Buffer error – AE CS4 and Latest Mac
    Posted by Butch Mcdonald on June 30, 2010 at 3:27 am
    I’ve tried everything I can to find out info on this ( only found docs from 2004 or 2006)… can anyone tell me why cs4 and the latest mac with 16 gig of ram gives me this error. My partner has a similar machine with more ram but the only difference is that he is on Leopard and I am on Snow Leopard. His machine gives the same results.
    The only way I can complete a render is to purge all then restart render from just before error report and keep repeating this process until I finally get to the end of my comp. Then I have to piece it together in post. Really annoying for a brand new machine.
    Most of my comps are working in 3D space, sometimes I even get the error with standard def comp sizes with footage or images no larger than HD.
    Can anyone help
    Cheers
    Butch Mcdonald replied 16 years, 1 month ago 3 Members · 3 Replies
  • Todd Kopriva
    June 30, 2010 at 8:59 am
    Those older documents that you refer to are just as relevant now.
    The main reason that we made After Effects CS5 a 64-bit application was so that problems like this dreaded image buffer error would never happen again.
    For After Effects CS4, I recommend that you try reducing the RAM requirements for rendering of the frames in your composition. Here’s a section in After Effects Help that gives information about how to go about that.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Andrea Sorrentino
    July 1, 2010 at 5:45 am
    For me, choosing Edit > Purge > Image Cache fixed the problem. I have to do it before each render.
    Also here are more possible solutions:
    https://generalspecialist.com/2006/11/avoiding-after-effects-error-could-not.asp
    Good luck 🙂
  • Butch Mcdonald
    July 1, 2010 at 5:57 am
    Thanks Todd,
    I think I am pushing the bounds a bit with my project…the only thing i have not tried is the little secret menu, but anyway I think I might upgrade if that’s going to stop this really annoying problem.
    Thanks again for your reply
