Activity › Forums › Apple Final Cut Pro Legacy › Can’t copy and paste into new sequence (with new settings?)
  • Can’t copy and paste into new sequence (with new settings?)
    Posted by Brad Dececco on February 28, 2013 at 1:58 am
    I have a 24P (Canon 5D Mark II) project I have edited into a sequence and a tv (Europe) station needs it in PAL and at a much smaller size (720×576 and anapomorphic). I was told I can take the 1920 HD sequence, copy and paste it into the new sequence – but when I do that, it won’t let me paste into the new (SD) timeline. Any idea how to get around this? Any help appreciated, thanks!
    Todd Gillespie replied 13 years, 6 months ago 3 Members · 5 Replies
  • Todd Gillespie
    February 28, 2013 at 2:03 am
    Hmmm. No, that’s not really the way to ‘convert’ your sequence.
    Easiest would be to drop your original sequence NEST it into a PAL sequence-then adjust. Although if you don’t need to change anything in the sequence, you’re probably better making a ProRes copy of the sequence, then use Compressor to do the pull-down and HD-SD conversion.
    Good Luck,
    Todd
    Todd at UCSB
    Television Production
  • Shane Ross
    February 28, 2013 at 2:08 am
    Also look at nattress.com and the STANDARDS CONVERTER plugin. But really, that’s for when you drop a PAL clip into an NTSC timeline and want it to look good. Or NTSC into a PAL timeline. Not something I’d use for a whole show.
    Export a full res Quicktime…use Compressor to convert.
    Shane
    Little Frog Post
  • Todd Gillespie
    February 28, 2013 at 2:12 am
    Shane’s correct. Forgot to mention, I use Nattress.
    Which is why the ‘nest’ sequence option is a good idea if you have that plug-in. Then you can just apply it to the entire sequence in one stroke.
    todd
    Todd at UCSB
  • Brad Dececco
    March 4, 2013 at 1:16 am
    Not sure what the “nest” sequence option is? is this something extra or is it in the regular compressor settings? Can you guys break it down for me, more step-by-step? Sorry but I have never done a conversion in compressor, not sure how to do al this stuff? I also have to make a 16:9 sequence (24P) which was shot at 1920, into a “16:9 FHA” at 720×576 -have no idea how to execute this. Any (super-basic) instructions greatly appreciated! Thanks!
  • Todd Gillespie
    March 13, 2013 at 4:38 pm
    Sorry Brian.
    Didn’t see your response. Hope you solved it, but ‘nesting’ a sequence is simply placing a sequence (your edited final) into another sequence (with the NEW output settings you need) and export.
    Good Luck,
    Todd at UCSB
