Activity Forums Apple Final Cut Pro Can’t copy and paste effects on synchronized audio
  • Can’t copy and paste effects on synchronized audio
    Posted by Bryan Fowler on July 20, 2011 at 7:38 pm
    I’m sure someone else has run into this.
    I have synchronized clips that I put in the timeline, or whatever you call it now.
    I did the ‘break apart clips’ command so I could fade between the lav and the boom mic as needed.
    I added the Voice Over Enhancement to the audio tracks, tweaked it to taste.
    Then tried to copy it to other audio… won’t work.
    tried selecting just the audio track, both audio tracks, only the video track. ALL the tracks. hit CMD-OPT-C and then CMD-OPT-V. nothing. tried using the menu. nothing.
    what simple thing am I missing?
    What more info can I tell you to help?
    Bryan Fowler replied 15 years, 1 month ago 1 Member · 1 Reply
  • Bryan Fowler
    July 20, 2011 at 7:58 pm
    well it started working. Not sure what I did differently.
    But it doesn’t paste the changes I’ve made, just the base preset. So…kinda useless unless I’m missing something.
