Activity Forums Apple Final Cut Pro Legacy Can’t control UVW 1800
  • Can’t control UVW 1800
    Posted by Jeffrey Weiser on June 5, 2010 at 5:06 pm
    I have a G5 dual processor Mac and just upgraded to Leopard 10.5.8 and driver software for AJA Io 3.1. I can play and digitize manually from the machine, but when I’m in the digitizer, Final Cut (6.0.6) can’t operate the Beta SP Machine. I can import footage just fine if I hit play on the machine. I’ve trashed prefs and re-installed the latest AJA Io software, but I can’t Play or Stop the UVW-1800 from the keyboard as usual. Any suggestions? Thanks.
    Jeff Weiser
    Director/Cinematographer
    Directors Syndicate
    jeffweiser@earthlink.net
    Jeffrey Weiser replied 16 years, 3 months ago 3 Members · 5 Replies
  • Steven Gonzales
    June 5, 2010 at 5:11 pm
    Which device control setting are you using?
  • Jeffrey Weiser
    June 5, 2010 at 5:39 pm
    In Audio/Video settings I have it set AJA Io RS-422 NTSC. I get a message that say “warning=port needs to be set”.
    In the Capture/Presets menu I have it set at AJA Io: SMPTE/N10 8bit NTSC 48K
    I also get a message “Unable to initialize video deck. You may still be able to log offline or use Capture Now”.
    I have pulled and re-seated my RS-422 cable going from the AJA to the deck as well.
    Jeff Weiser
    Directors Syndicate
  • Arnie Schlissel
    June 5, 2010 at 5:58 pm
    2 things. Your deck may be in local, it should be in remote. And your capture preset should be for Betacam, not SMPTE/N10. Beta decks have different levels than SMPTE/N10.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Jeffrey Weiser
    June 5, 2010 at 10:23 pm
    Nothing has worked so far. Any other possibilities? I’ve tried using the AJA control panel as well.
    Jeff Weiser
    Directors Syndicate
  • Jeffrey Weiser
    June 5, 2010 at 11:25 pm
    I re-installesd the old 2.1 AJA software and it runs perfectly.
    Jeff Weiser
    Directors Syndicate
