Activity › Forums › Compression Techniques › Can’t compress Mpeg to the right specs
  • Can’t compress Mpeg to the right specs
    Posted by Andreas Kossionis on September 27, 2012 at 6:57 pm
    Hello!
    I’m working on this promo video for a theatre company and have compressed it in different formats for all the different places that is being shown. No problems so far.
    Well for the last one I had to do, they sent me these specs:
    Format: MPG 1 or MPG 2
    Max. resolution: 640×480
    Max. bitrate: 4.000 bit /sec
    FPS: 25
    I use an uncompressed avi file rendered from AfterEffects and I use Adobe Media Encoder for compressing to Mpeg. (Although I have tried other converters too)
    So I sent the video but it wouldn’t play, played a bit with settings sent a second version same thing.
    So I asked for one of their previous videos that plays well on those screens and they sent me one with the following specs:
    Format : MPEG-PS
    File size : 25.0 MiB
    Duration : 1mn 11s
    Overall bit rate mode : Variable
    Overall bit rate : 2 943 Kbps
    Video
    Format : MPEG Video
    Format version : Version 1
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Duration : 1mn 11s
    Bit rate mode : Variable
    Bit rate : 2 884 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 1.422
    Frame rate : 25.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.376
    Stream size : 24.5 MiB (98%)
    I have no idea how to do this. The aspect ratio of the video is a bit wider than the usual 4:3 but it’s not as wide as 16:9 and I have never seen it before.
    Any ideas how to do this?
    Thank you in advance
    Andreas
    Andreas Kossionis replied 14 years ago 1 Member · 1 Reply
  • Andreas Kossionis
    September 27, 2012 at 7:30 pm
    I work on Windows 7 Home Premium version 6.1
    Adobe AE Cs5.5
    Adobe Media Encoder Cs5.5
    I’m also trying different converters like Movavi 10 etc
