Activity Forums Adobe After Effects Can’t compress enough!!
  • Can’t compress enough!!
    Posted by Tabby Kirby on July 26, 2011 at 2:48 am
    Ok, So yes, this is my first time using after effects, but i really need some help.
    I made a simple 5 minute count down with a background that I made in photoshop and the first time i rendered it, it was 44GB. So after about an hour of reading i found out I needed to compress it, once i figured out how to do that I used Sorenson3, simply because I had seen it said that it was a good compressor and got it down to 11GB. This weekend I talked to a friend who has been working with this stuff a couple of more months than I have and he said to use H.264, when I did that It only brought it down to 7.46GB.
    SO I have no clue what else to use or if there is another setting on the video that I have yet to set right, if I could get some help that would be awesome I have been waiting for this to be done for over a week now, thanks,
    Tabby
    Tabby Kirby replied 15 years, 2 months ago 4 Members · 6 Replies
  • Tudor “ted” jelescu
    July 26, 2011 at 7:26 am
    It always helps when you give a bit more information in your post- like what version of AE, what are the specs on your system, what format are you working in (frame size, rate, color space).
    For compression AE is not the best tool. You can run your rendered piece through Adobe Media Encoder or you can render your comp directly from Encoder. For more advice I would need to know also how you want to use the final piece- will it be introduced in a cut together with other material, will you post it on YouTube/web, DVD playback, BlueRay…? There are presets for almost all your needs in Encoder.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Thomas Hardy
    July 26, 2011 at 8:12 am
    I don’t know sorenson3, but if you are trying to encode in h264 make sure you are using the addecuated bitrate, you can make the video the size you want with h264, try with Ripbot, set it to 2pass, and lock size to the size you need.
    Thomas Hardy.-
    Newbie and Learning.
  • Tabby Kirby
    July 26, 2011 at 10:34 am
    Sorry about that, I’ve got CS5. And with this video we will be using it for a pre service countdown that will be projected, simply put with some music. So i’m importing it into an .mov file with Quicktime NTSC at a frame rate of (29.97) and the frame size is 1920 x 1080.
    ….i Hope that enough info, again, sorry about that.
    -Tabby
    July 26, 2011 at 3:38 pm
    If you have playback from a computer make sure (like Dave suggested) that your projector can do 1920×1080. If not, then it’s overkill.
    You will find plenty of presets in Encoder for 1920×1080 and 1280×720.
    If your playback is from a regular DVD player you will most likely play a SD widescreen file.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Todd Kopriva
    July 27, 2011 at 2:45 am
    I agree with the point about thinking backward from delivery requirements. This page gives some good resources for getting started with such issues, especially this article here on the COW about planning your work.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Tabby Kirby
    July 27, 2011 at 12:41 pm
    Thanks guys!
    I was able to change the size of it to 1280 x 720 and then ran it through Adobe Media Encoder and it put it down to 385MB. So, thank you guys very much I have learned a lot from this.
    -Tabby
