Activity Forums Adobe Encore DVD can’t choose : don’t transcode
  • can’t choose : don’t transcode
    Posted by Rombrero on October 8, 2006 at 10:12 pm
    After i have imported a mpg-2 file (which is according to DVD specifications, checked with bitrate viewer)i can not choose: don’t transcode (it is in grey)
    Source of the file is: digital satellite broadcast
    I have checked in graphedit and mainconcept is the audio and video decoder for the imported file.
    I would like to preserve the highest quality and avoid transcoding. Does anyone know what i am doing wrong
    Justin Chenier replied 19 years, 11 months ago 3 Members · 3 Replies
  • Vince Becquiot
    October 9, 2006 at 3:58 am
    Could it be that the audio is set to Dolby Digital in your encoding preferences ?
    Try changing it to mpeg2 or PCM.
    Vince
  • Rombrero
    October 9, 2006 at 12:40 pm
    Hello Vince,
    The audio part is not the problem because i demuxed the file (the ac3 part has no problems because it is labeled as: don’t transcode)
    I also tried to reinstall adobe encore and the mainconcept filters with no succes.
    The file is anamorf widescreen (bitrate about 7 mb average but never above 8), but i think that shouldn’t matter.
    Ronald
  • Justin Chenier
    October 11, 2006 at 1:49 pm
    Are you sure that the file is selected before you select the transcode setting. I spent an hour trying to figure-out the same thing once. When I selected the item, right-clicked, selected Transcode Settings, I was finally able to select Don’t Transcode.
