Activity › Forums › Compression Techniques › can’t chg Compressor dvd Field Dom setting
  • can’t chg Compressor dvd Field Dom setting
    Posted by Paul Dougherty on April 24, 2012 at 11:20 pm
    After not using Compressor with an Avid Quicktime (ntsc out) to make a dvd in a while, I ran into strobing / field dominance problem. I had used the default Best Quality 90 min forgetting what a wise man said on Cow “never let compressor figure out the field order” When it dawned on me to set Field Dominance in the Video Format tab to Bottom* – I couldn’t do it, it was stuck on Automatic and grayed out. Clicking the little gear icon to the right didn’t help. Luckily I stumbled on another older dvd setting where I somehow succeeded in changing Field Dominance to Bottom in the past, used that and problem solved.
    Should this kind of thing come up again, what was I doing wrong? Why couldn’t I change Field Dominance?
    Thanks in advance,
    Paul
    *copied the default Best Quality 90 and tried to make the change on the copy
    Jeff Greenberg replied 14 years, 5 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    May 1, 2012 at 2:22 am
    You have to have the compressor preset applied to a clip to be able to make changes like that. Just changing the raw preset may not work. Apply, adjust, save and you should be good.
    Best,
    Jeff I. Greenberg
    Editor/Author/Speaker/Consulting
    My NAB seminar schedule, contact info and more
