Activity Forums VEGAS Pro Can’t change text placement numbers
  • Can’t change text placement numbers
    Posted by Christian Smith on May 27, 2020 at 10:26 pm
    Working on a video that is due tonight. For the past 45 minutes, every time I attempt to change the values of my text placement (delete numbers), the cursor goes to the beginning of the number.
    The issue is only resolved after I close out of Vegas. But even upon restarting it, the problem reappears moments later. Any help would be appreciated.
    Steve Rhoden replied 6 years, 3 months ago 3 Members · 2 Replies
  • Dimitrios Papadimitriou
    May 28, 2020 at 2:42 am
    Instead of using text placement leave the text centered then use pan/crop instead. Or use one of the other text tools. But pan crop will let you enter numbers as well.
  • Steve Rhoden
    May 29, 2020 at 9:33 am
    Just simply use the Pan/crop feature to easily reposition your text easily.
    You will find this method works even better in the long run.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
