Activity Forums Adobe After Effects cant change multiple properties anymore
  • cant change multiple properties anymore
    Posted by Josh Earle on February 20, 2025 at 8:15 am
    I used to be able to select a bunch of layers that have masks on them, hit F for feather, unfolding all layers to open their feather properties. Then changing one would change all. This doesnt work anymore. Anyone know if this is a new update? I recently installed a wacom driver that has been doing some weird shit, but I think only when its plugged in.
    Whats going on?
    Graham Quince replied 1 year, 7 months ago 2 Members · 1 Reply
  • Graham Quince
    February 20, 2025 at 12:49 pm
    Just tried it. Having the layers all selected and hitting F then trying to change the feather only works for the top layer that I’m adjusting.
    But if you select each mask feather property instead then you can adjust multiple properties at once. I don’t know if this is something new as I hadn’t tried to adjust mutliple feathers before.
