Activity Forums Adobe Encore DVD Can’t change highlight group for button in Encore CS3
  • Can’t change highlight group for button in Encore CS3
    Posted by Marc Thomas on August 5, 2010 at 8:27 pm
    Subject title says it all.
    I’m so confused. I made a DVD menu last week… buttons and highlights work fine.
    Made a new menu last night, and I can’t change the “highlight” group number.
    There’s just a “–” instead of a number and it’s greyed out… I can’t click on it to get the drop down menu.
    I imported this menu into the the first project… and the 1st menu still works fine, but the second is STILL greyed out?!!
    FYI… the first menu was 4:3 and the second 16:9, but I don’t see how that should matter.
    Any thoughts?
    Jason Jenkins replied 15 years, 1 month ago 3 Members · 4 Replies
  • Marc Thomas
    August 5, 2010 at 8:32 pm
    Any new project I try to make gives me the same greyed out “highlight” option.
    If it weren’t for the 1st project working properly… I’d say that Encore won’t let you change the group.
    FYI… I tried to manually change the group from “(=1)” to “(=2)” in photoshop… but still greyed out.
    Also, when the button is selected, instead of turning from yellow to red… it is yellow and then disappears.
  • Ryan Krumm
    August 16, 2010 at 1:08 am
    I was having the same problem. Did you make your buttons in Photoshop. If so, this is your answer:
    https://www.adobe.com/designcenter/encore/articles/enc15subpic_02.html
    The highlight groups are based on the colors you made in Photoshop.
    You can also go to Menu>Edit Menu Color Set and hit the New Color Set button. That will make a copy of the Automatic Color Set (which is based on your Photoshop Colors) and you can tweek it from there.
  • Marc Thomas
    February 25, 2011 at 6:39 am
    Sorry for the late reply…
    I finally found a solution, but forgot to come back and post it here in case anyone else had the same problem.
    (1) Left-click on the menu you’re working on (in the “project” list).
    (2) Look at the “properties” on the right side.
    (3) Click on “color set” (it will be set to “automatic”) change it to “menu default”.
    And VOILA! Now you have the option to change the Highlight group for any button.
    Enjoy 🙂
    Marc
  • Jason Jenkins
    July 28, 2011 at 7:53 am
    Thank you, Marc! You just spared me some late-night frustration.
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
