Activity Forums VEGAS Pro can’t change format to mp4 under mainconcept / 1920 x 1080
  • can’t change format to mp4 under mainconcept / 1920 x 1080
    Posted by Brent Holland on June 22, 2013 at 7:15 pm
    render as / mainconcept AAC AVC / Blue-ray 1920 x 1080 60i / customize template / system / Format grayed out video elementary stream(avc)
    Vegas pro 12 build 563
    anyone else having the same problem?
    I am able to render to MP4 under “mainconcept AAC AAVC ” for everything in the list except it is also “grayed out”. Once I get to anything “Blue-ray”, then , under “format” it defaults to “video elementary stream (avc) and is also grayed out.
    I have already uninstalled 12 and then reinstalled it
    I’m thinking I need the H.242 something codec ?
    John Rofrano replied 13 years, 2 months ago 2 Members · 3 Replies
  • John Rofrano
    June 23, 2013 at 2:50 pm
    [Brent Holland] “render as / mainconcept AAC AVC / Blue-ray 1920 x 1080 60i / customize template / system / Format grayed out video elementary stream(avc) Vegas pro 12 build 563 anyone else having the same problem? “
    This is not a “problem” and is the intended behavior. What Sony has done is make it harder for you to make a bad choice so depending on your starting template, they gray out items that should not be changed. Since you can only use an AVC stream for Blu-ray they don’t let you change it. If you start with the Internet HD templates, they are set to MP4 because that’s the container you should use for Internet delivery.
    So nothing is wrong, you don’t need any codecs, you just need to start with the correct template for what you are trying to do.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Brent Holland
    June 25, 2013 at 12:25 am
    thx John say “hey” to Steve. I am going to use the main concept HD Internet 720 for vimeo and youtube, hopefully that will do the trick thx again.
    oh quick question is there a keyboard shortcut for zooming in and out in pro 12? also is there a short cut to go to end of track and beginning of track?
  • John Rofrano
    June 25, 2013 at 10:27 am
    You can zoom in and out of the timeline with the scroll wheel on your mouse. Also Up/Down Arrow and Ctrl+Up/Down Arrow will zoom. Ctrl+Home or ‘W’ gets you to the beginning of the project and Ctrl+End gets you to the end.
    All of the keyboard shortcuts are in this document from Sony:
    vegaspro12.0_keyboard_commands_enu.pdf
    ~jr
