Activity Forums Apple Final Cut Pro Legacy Can’t change clip settings
  • Can’t change clip settings
    Posted by Jonny Flint on May 22, 2008 at 4:21 pm
    Hello,
    I’ve been requested to change the settings to a sequence and consequently to some clips aswell. I imported footage from some P2 cards with Final Cut Pro (6.0.3) reading them as 1080i50, but my client wants these changed to 1080p25 so all I’m trying to do is change the field dominance to “None”. Changing the sequence is no problem but when I attempt to change a clip’s settings (top left browser -> right click -> clip settings) the following error message comes up:
    “No items have files that are applicable to this operation”
    I have never had this problem before, although saying that this is the first time I have used P2 cards. Does anyone know why it is saying this and whether it can be resolved?
    Jonny
    Rafael Amador replied 18 years, 3 months ago 2 Members · 5 Replies
  • Rafael Amador
    May 22, 2008 at 4:28 pm
    You must change the field order of the sequence to NONE and drop a de-interlacer filter to the i50 clips in the sequence.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Jonny Flint
    May 22, 2008 at 4:32 pm
    okay thanks. and it doesn’t matter whether i put “upper” or “lower” as the field order in the filter?
  • Rafael Amador
    May 23, 2008 at 2:07 am
    Right. If you use FC’s de-interlacer it doesn’t matter if you hoose Upper or Lower.
    JVC DTV-17″
  • Jonny Flint
    May 23, 2008 at 1:22 pm
    sorry, just to clarify:
    i want to change the sequence settings from “1080i50” to “1080p25” and change the field dominance to “None”.
    and deinterlace all the clips.
    is this correct?
  • Rafael Amador
    May 24, 2008 at 9:50 am
    [Jonny Flint] “i want to change the sequence settings from “1080i50” to “1080p25” and change the field dominance to “None”. “
    If your sequence is 1080i50 and you set Field Dominance NONE, you get a 1080p25 sequence.
    Then de-interlace the clips and thats all.
    JVC DTV-17″
