Activity › Forums › Apple Final Cut Pro Legacy › can’t center pan audio clips
  • can’t center pan audio clips
    Posted by Gerret Warner on September 30, 2011 at 7:59 pm
    I’ve edited on FCP for years but never come across this problem before. I can’t center pan my audio clips so they play mono into both speakers. Is it possible I set a preference unintentionally? Or might it be something else?
    GW
    Gerret Warner replied 14 years, 12 months ago 3 Members · 3 Replies
  • Mark Spano
    September 30, 2011 at 8:30 pm
    It is likely that your Sequence Audio Output Setting is set to discrete outputs. Go into your Sequence settings – Audio Output tab, and choose the Stereo Monitoring preset. You should get your pan controls back.
  • Michael Gissing
    September 30, 2011 at 10:46 pm
    Are the clips linked stereo? Try unlinking and see if the panning is now available.
  • Gerret Warner
    October 3, 2011 at 4:29 pm
    Many thanks, Mark. that did the trick.
    Gerret
