Activity Forums Apple Final Cut Pro Legacy Can’t capturing only audio
  • Can’t capturing only audio
    Posted by Itamar Kool on August 23, 2007 at 10:33 am
    I tried to capture my own voice trhough a microphone for off line purposes. I see the green volume meter react so the signal comes through to FCP. I select only audio capture in the clip tab of the capturing window and I push the capture now button.
    After a moment I get the message that I can’t capture because there is no video signal. Well that’s right!!! That’s exactly what I want, so why the @#$%^&**!!! can’t I capture????
    Kool En De Anderen
    MAC Pro/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
    http://www.koolendeanderen.nl
    Jerry Hofmann replied 19 years ago 3 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    August 23, 2007 at 11:20 am
    Use the Voice Over tool instead.
    Jerry
  • Itamar Kool
    August 23, 2007 at 1:37 pm
    OK used it. Didn’t realise it was so simple. Thanx
    Kool En De Anderen
  • Jeremy Garchow
    August 23, 2007 at 1:45 pm
    You can also run ANY video signal to your Kona card, anything at all as long as it’s video. If you have video running to the card, and then deselect it and record your audio, you should be good.
    Jeremy
  • Itamar Kool
    August 23, 2007 at 2:57 pm
    Strange thing is though that I used to be able to record audio this way. Why did they change that??
    Kool En De Anderen
  • Jeremy Garchow
    August 23, 2007 at 3:06 pm
    As far as I know, it’s pretty much always been like this.
    Jeremy
  • Itamar Kool
    August 23, 2007 at 3:14 pm
    I always used to do it without video…
    Kool En De Anderen
  • Jeremy Garchow
    August 23, 2007 at 3:19 pm
    Sorry. I am not sure when the switch happened.
  • Jerry Hofmann
    August 24, 2007 at 12:38 pm
    For scratch tracks, I think it’s way good. I use this USB headset made by Plantronics and it just works…
    Jerry
