Activity › Forums › Adobe Premiere Pro › Can’t capture video in capture window
  • Jon Barrie
    September 4, 2011 at 12:39 am
    I have a (once was $8000) Sony HDV Z1P and it can’t playback LP mode tapes as it is not a format it records in. Unless you can get the camera to playback the tape on its own then no software will be able to ingest it.
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Jon Barrie
    September 4, 2011 at 12:58 am
    I just did some research on your model camera and I apologise. It seems your camera can recording in LP mode when set to DV format.
    Perhaps the camera is not set properly in playback mode (VTR) so you aren’t able to see the image on the camera… Is there an Auto format setting when a tape goes in and plays that it adjusts to the correct playback mode?
    It is possible that the camera is sending a mixed signal down the firewire in auto mode. You may need to set it to DV and LP playback for PPro to recognise the signal properly..?
    Another possiblity is that the Recording Capture settings are not set to DV. You can have control over the deck in HDV capture settings but won’t actually get to capture.
    Im sure there is someone out there with a successful use of your situation with the same camera and an LP tape.
    – JB
    Jon Barrie
    aJBprods
  • Jon Barrie
    September 4, 2011 at 1:16 am
    I found this online version of the CanonXLH1a manual that has this to say about the LP mode recording and playback function and limitations and potential problems with it.
    – JB
    Jon Barrie
    aJBprods
  • Roger Triv
    September 8, 2011 at 12:01 pm
    Jon, I recorded in DV not HDV. I set it for LP. I need to capture the video in the PP capture window. I can again control the camcorder (play, record, stop, etc…) from PP CS5 in this mode, but nothing shows in the capture window. I try all the presets in PP, and nothing works. I don’t see why the camcorder can’t capture, even though it has presets for DV. Do I need a piece of equipment just to copy the tape in DV? If so, what would you recommend? Also what would the DV settings be in PP CS5? Thanks
  • Jon Barrie
    September 8, 2011 at 12:36 pm
    Hi Roger,
    Sorry for all the confusion. It appears we were all asking you to make sure everything was set to HDV and not DV. When in fact as you have recorded in DV LP mode, you DO need the settings in DV mode. The Device Controller is the same for DV or HDV so that’s why you were able to control the camera. You couldn’t see the image as we all thought you were working with HDV not DV. Then then we missed a step in confirming the settings for DV not HDV.
    Make sure the camera is set to Playback or VTR in DV LP mode and not Auto.
    Here is a screen grab of what needs to be set for DV capture.
    I really hope this helps with your situation. I can’t imagine how frustrating this must be for you having gone on for so long.
    I will do my utmost to be sure and ask what format users have recorded in next time before assuming a HDV camera was recording in HDV. Shame on me.
    Again. Deepest apologies, this “should” get you going.
    – JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
  • Roger Triv
    September 9, 2011 at 3:09 am
    Jon,
    I set everything you said in your e-mail.
    When I try to record again and then stop, a error windows pops up and said “recorded capture no frames”.
    My camcorder viewfinder shows:
    DV 16:9
    16 bit
    60i
    LP
    What preset in PP should I have PP set on?
    I tried several presets and nothing works.
    Can you give me exact setting in PP for my DV tape in possible?
    Camcorder Canon XL H1A
    Thank you, Roger
  • Jon Barrie
    September 9, 2011 at 5:14 am
    I am interested in whether your camera can ingest some footage that has been captured in DV SP…
    That screen grab I showed about known issues related to LP mode recordings could be in play.
    Let’s at least eliminate the possibility the camera or cable or FW port is the problem.
    JB
    PS: The sequence type makes no difference to the capture settings.
    You could have a HDV sequence but the capture settings will remember the last setting used, so if it was DV that would be what it is trying to ingest. (It doesn’t auto correct the ingest based on the sequence settings)
    Jon Barrie
  • Todd Kopriva
    September 12, 2011 at 11:31 pm
    There are some fixes related to HDV capture in the Premiere Pro CS5.5 (5.5.1) update.
    After you’ve installed that update, let us know how it works for you.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
Page 2 of 2
