Activity Forums AJA Video Systems Can’t capture through AJA i/o
  • Can’t capture through AJA i/o
    Posted by Christian Vorbeck on March 30, 2006 at 8:33 pm
    Hi
    I can’t capture anything through my I/O. I’m getting “An error occurred while configuring Quicktime using the current capture preset”
    I’m trying to capture component 10 Bit from betacam SP. I get the same message when trying to capture via component, composite or s-video.
    I’ve checked cables and everything seems ok
    On the front of the I/O the lights are where they’re supposed to be (Analog, composite, ntsc)
    Please i need help
    Gual 2 G5, 2 Gb Ram, FCP 5.0.4, QT 7.0.3, Graid FW800
    Christian
    Thanks Experts
    Christian
    Christian Vorbeck replied 20 years, 5 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    March 30, 2006 at 9:51 pm
    Are you io and FW800 on separate busses?
  • Christian Vorbeck
    March 30, 2006 at 11:35 pm
    I don’t have any new firewire 800 card installed, just as it came. I/O is connected to the firewire 400 port and the Graid is connected to the firewire 800 port that came with thw G5. But the thing is that when I hit log & capture I get the error. It does’nt even try to capture
    But i deleted i/o presets and created new ones from scratch and I was able to capture. It seems as if the presets that came with the I/O installer disk are damaged. None of them works.
    Christian
    Thanks Experts
    Christian
  • Bob Zelin
    March 31, 2006 at 1:01 am
    you should download the AJA I/O drivers from the http://www.aja.com website under Support. These are the latest working drivers, and I can assure you, they work just fine.
    Bob Zelin
  • Christian Vorbeck
    March 31, 2006 at 8:16 pm
    Thanks Bob
    That was it. Now is working like a charm
    Christian
    Thanks Experts
    Christian
