Activity Forums Apple Final Cut Pro Legacy Can’t Capture – JVC 720p
  • Can’t Capture – JVC 720p
    Posted by Max Frank on August 12, 2010 at 11:38 am
    This seems to be an old and apparently common issue, but I can’t seem to find the solution.
    I was given a tape apparently shot on a JVC GY-HD110U 720/60P
    The deck reads reads the tape fine – but I can’t get FCP to recognize the tape.
    In the capture window FCP recognizes the timecode and can control the tape, but I’m not getting any pictures or audio.
    In fact, I’ve tried 3 different decks and I’m getting the result.
    Is there a special JVC codec I need to download?
    Any other advice?
    Wayne
    FCP 6.0.6
    OS X 10.5.8
    Macbook Pro
    Max Frank replied 15 years, 9 months ago 3 Members · 3 Replies
  • Shane Ross
    August 12, 2010 at 11:40 am
    Which decks? These won’t play on Sony decks…different HDV formats. When you say the decks read them fine, can you play them back on a monitor? Or do you mean that they can see the timecode?
    You need to play these back in a JVC deck, or JVC camera.
    Shane
  • Rafael Amador
    August 12, 2010 at 12:32 pm
    That format is supported by FC since v6.0.2 (great version) and If I’m not wrong JVC has been the only manufacturer to implement it. As Shane points you will need a JVC device to play the tapes.
    rafael
    http://www.nagavideo.com
  • Max Frank
    August 12, 2010 at 3:19 pm
    Thanks for the prompt replies, Gents –
    I can’t recall the pro-deck I used, but I’ve also tried 2 Sony cameras.
    With all three they play the tapes perfectly [ie, I get the video/audio in the monitor] – but it’s not recognized by FCP.
    I’ll try hunt down a JVC HDV camera. Somehow.
    Wayne
