Activity › Forums › Apple Final Cut Pro Legacy › Cant capture HDV from canon xh-a1s into final cut express
  • Cant capture HDV from canon xh-a1s into final cut express
    Posted by Will Crowe on November 1, 2009 at 5:12 am
    I am trying to capture hdv in to final cut express 4. It never seems to recognize the camera except when capturing in dv. I was looking for any tips on capturing hdv.
    Will
    Robert Starkey replied 14 years ago 7 Members · 8 Replies
  • 8 Replies
  • Jeff Mueller
    November 1, 2009 at 7:01 pm
    I’ve had similar problems with my Canon XL-H1 and FCP and there seem to be many variables, but a couple things to check are: 1) in the camera menu, Playback Mode needs to be set to HDV NOT Auto, if it’s on Auto, turn it off. 2) while you’re in the menu make sure that HDV downconverting is also OFF. 3) use the HDV Firewire BASIC video setting. 4) unplug any unnecessary Firewire devices.
    Let us know what works.
  • Will Crowe
    November 1, 2009 at 9:39 pm
    I didnt realize i had the hd down conversion on. That made it work. Thank you very much
    Will
  • Anne Welles
    December 10, 2009 at 6:52 pm
    I’m having the same problem – but in Signal Setup the Playback mode and HD Down-Conversion options are grayed out so I can’t manipulate them – anyone know why this is?
  • Ricardo Orozco
    March 3, 2010 at 9:22 pm
    i have the same problem than Anne please help!
  • Brian Muntz
    April 18, 2010 at 6:01 am
    I am having the same issue. I just bought the XH A1s x 2 units 24 hours ago, and I am flying over seas to do a documentary. Please anyone, can you help. I am sure its a simple issue. Perhaps out-of-the-box bad config.
    Regards, Brian
    brianmuntz @ gmail.com
    Brian Muntz
    Pro Photographer, Videographer and editor.
    Documentary Producer / Director
    Fin art Photography
  • Brian Muntz
    April 18, 2010 at 6:11 am
    I knew it was a simple problem to fix the greyed out options, just Canon can’t foresee these issues to a degree of being green and letting us know.
    Just unplug the unit from the firewire and then change the settings and then pug it back in again and vole, it works. Sheeeez, Hope this thread finds all the new-gen (greenhorns) owners out there and helps!
    Brian
    Brian Muntz
    Fin art Photography
  • Matthew Marchesi
    April 23, 2012 at 6:18 am
    This:
    “Just unplug the unit from the firewire and then change the settings and then pug it back in again”
    and the OPPOSITE of this:
    “while you’re in the menu make sure that HDV downconverting is also OFF”
    made it work for me. I needed to turn HDV downconverting ON.
    I’m using FCP7 on Lion, no updates to Lion or FCP.
  • Robert Starkey
    October 1, 2012 at 12:02 am
    I am having similar problems with the same camera and final cut express 4… I was capturing without any issues then one day I started getting cannot initilize hdv deck. i’ve tripled check all settings nothing has changed on the camera or program settings… switched out firewire cable still no luck any insight????
