Activity Forums Apple Final Cut Pro Legacy Can’t capture HDV – 1080i60
  • Can’t capture HDV – 1080i60
    Posted by Gary Turner on July 24, 2007 at 11:52 pm
    I’m new to doing HD.
    I’ve shot a scene on a Sony HDR-Z1U in 1080i60.
    Placed the tape in my Sony HDV 1080i deck.
    Went in to FCP 5.1.4
    set Easy Setup to HDV – 1080i60
    It gave me a default setup of:
    Sequence Preset: HDV – 1080i60
    Capture Preset: HDV
    Device Control Preset: Sony HDV Fireire
    Playback Output Video: None
    Playback Output Audio: Default
    Edit to Tape/PTV Output Video: HDV (1440 x 1080) 60i
    Edit to Tape/PTV Output Audio: HDV
    FCP finds the deck no problem. I hit (Apple key + 8) to capture and the window comes right up. The screen is black.
    I can hit the space bar and the deck plays, but no video in my capture window.
    If I try to set an in & out and do a capture anyways it the deck goes to cue up the in point and just keeps going right past it. Never captures anything.
    Am I the only one this is happening to?
    My computer is an Intel Mac with Xeon CPUs. OSX: 10.4.10
    And I’m capturing through a fireware 400 connection.
    Pkammer replied 18 years, 10 months ago 6 Members · 13 Replies
  • 13 Replies
  • Tom Wolsky
    July 24, 2007 at 11:54 pm
    Any other drives or devices connected to the computer?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Gary Turner
    July 24, 2007 at 11:56 pm
    It is an almost direct firewire connection. The firewire is going through a firewire switcher that allows us three Producer/Directors to share the same deck.
  • Tom Wolsky
    July 25, 2007 at 12:27 am
    Connect the deck directly to the computer. I don’t know what kind of a computer it is or anything else about your system so it’s hard to guess what you might be doing. Full specs of computer, drives, OS, QT and software versions would be helpful. I’m guessing it’s the hub or the way everything’s connected. But I’m guessing.
    All the best,
    Tom
  • Gary Turner
    July 25, 2007 at 3:25 am
    Attempt to connect firewire directly to my IntelMac got the same results.
    As for all my specs most are in the first email. The only thing additional I could add is:
    Hardware Overview:
    Model Name: Mac Pro
    Model Identifier: MacPro1,1
    Processor Name: Dual-Core Intel Xeon
    Processor Speed: 3 GHz
    Number Of Processors: 2
    Total Number Of Cores: 4
    L2 Cache (per processor): 4 MB
    Memory: 8 GB
    Bus Speed: 1.33 GHz
    Boot ROM Version: MP11.005C.B04
    SMC Version: 1.7f8
    Serial Number: G86504AVUPZ
  • Tom Wolsky
    July 25, 2007 at 3:33 am
    Cable, camera, or port issue I’m guessing. Try swapping cables. Are you using the rear FireWire on the MacPro? Don’t use the front.
    All the best,
    Tom
  • 13 Create COW Profile Image
    13
    July 25, 2007 at 5:23 am
    Check your camera I bet it is set to down-convert the HDV to DV. Turn that off and you should be good.
    13
    July 25, 2007 at 5:42 am
  • Redford Givens
    July 31, 2007 at 5:35 am
    Sony HDR-Z1U
    I’m a newbie, but it appears that the Sony HDR-Z1U camera is not supported by FCP.
    A list of Qualified Devices for Apple Pro Applications is found at:
    https://www.apple.com/finalcutstudio/resources/devicelist.php#results
    Sony HDR-Z1U is not on the list for FCP.
    PP
  • Gary Turner
    July 31, 2007 at 8:02 am
    Quick response to a couple of replies.
    I did try switching to the rear Firewire port. Got the same results. Spoke with a tech support guy at Final Cut Pro. He says front or back port shouldn’t matter unless the front port happens to be damaged.
    He did add that both the HDV deck and camera I am using is rated for FCP. Though it has only been qualified for 1080i50 and not the i60. Again, he didn’t think that should have been the hang up.
    We tried both the deck and importing directly from the camera and got the same results.
    We’re on to our next theory. Maybe someone can confirm if we’re on the right track. Which is… While we did shoot in HDV and playback confirms this, we did not use an HDV tape. We used a regular DV tape. It does playback fine in both camera and HDV deck. And both show during playback that it is recorded in HDV mode. Is it possible that the only hang up is that we recorded to a DV tape?
  • Tom Wolsky
    July 31, 2007 at 9:36 am
    Most people shoot on regular DV tape. That you’re not shooting on HDV tape is not a factor. Has the tape been use before, with DV material?
    Many people capture from that camera in 1080i60 without problem. It’s possible there is a problem with one of your ports, or the cable. I would definitely keep the hub out of the loop. You did say there were no other devices connected I think. If you’re near an Apple store you might try taking in your camera and testing it on one of their machines.
    All the best,
    Tom
