Activity Forums VEGAS Pro Cant capture from Tape
  • Cant capture from Tape
    Posted by Ben Edwards on August 4, 2009 at 10:32 am
    I downloaded the Vegas Platinum Pro Pack Demo to give Vegas a Try. I went in to capture and it defaulted to my webcam. The Tape button was greyed out. I have a DV deck plunged into the computer and turned on. The deck is connected with a Pyro 1394 Card (Texas Instruments Chipset).
    Is capture from tape disables in the demo. The PC has also got Avid installed on it, I seem to remember reading somewhere that both have problems co-existing.
    Regards,
    Ben
    Norman Willis replied 17 years, 1 month ago 4 Members · 6 Replies
  • John Rofrano
    August 4, 2009 at 11:41 am
    I don’t know about Avid incompatibilities but does Windows recognize your camera when you plug it in? You should hear a sound that it was connected and it could be listed as a device in Windows. If this doesn’t happen Vegas Movie Studio will never be able to see it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Nigel O’neill
    August 4, 2009 at 12:58 pm
    You may check if Windows firewall or your firewall is blocking the 1394 port. This was a gotcha for me on Vista64.
  • Ben Edwards
    August 4, 2009 at 1:58 pm
    Which port does firewire use. 1394 sounds sensible so I am guessing it is something else;).
  • Norman Willis
    August 5, 2009 at 5:26 am
    Are there known incompatibility issues between Vegas and Avid?
  • Ben Edwards
    August 5, 2009 at 10:46 am
    I am not entirely sure but seem to remember someone mentioning it somewhere, sorry cant be more specific. I have now reinstalled windows and everything is working AOK. I do know that Avid is fairly invasive as it expects to be the main thing running on the box (due to its cost this is normally the case). I think I may start a new thread to get to the bottom of this.
  • Norman Willis
    August 5, 2009 at 4:25 pm
    Please do. Are you going to post it on the Vegas forum, or on the Avid forum?
    I love Vegas, but I would also like to know what other tools are compatible/available.
    Thanks.
