Activity › Forums › Apple Final Cut Pro Legacy › can’t capture from dv-tapes with pixel errors
Posted by Nis Boye on June 22, 2008 at 1:51 pmI have some dv-tapes shot on an old Sony PD-100, that I’m trying to capture into FCP 6.0.3 using a Sony DSR-11 tapedeck. All PAL devices.
Unfortunately the PD-100 was in dire need of a head-cleaning – so most of the footage has pixel errors. Eventhough a lot of the footage is useless I still need some of it – but I can’t capture it into FCP. I get the “Capture encountered a problem reading the data on your source tape” error.
I have tried to capture using the “non-controllable device” setting, but I still get the same error.Any idea how to fix this?
Lars Fuchs replied 18 years ago 4 Members · 7 Replies -
Don Greening
June 22, 2008 at 4:37 pmTry capturing using the “capture now” function and make sure the “on timecode break make new clip” is checked in your preferences.
If you’re still having problems then use iMovie to capture. It will also start a new clip at every break. Then you can import the iMovie DV stream files into FCP.
– Don
Rafael Amador
June 23, 2008 at 2:57 amAnd If you can not do it with FC, you can try with QT:
QT> File> New Movie Recording.
Rafael -
Nis Boye
August 7, 2008 at 8:52 amiMovie captured everything. And I now have all my tapes, with errors, in FCP.
Thanks!!
Rafael Amador
August 9, 2008 at 2:17 pmHi Nis,
iMovie is not the way to go. You capture DV Stream (a proprietary format of iMovie) that do not support TC, chops the movie in too many clips and you have always to render in FC.
Rafael -
Lars Fuchs
September 14, 2008 at 3:14 amHi Gang,
had the same problem. Tried iMovie before checking the forum, discovered that it worked, but without TC. Then I found this thread.
But can anyone explain why iMovie will capture a tape from the same PD-170 that FCP can’t capture from? (the same camera was used to record the footage.) During playback, audible gaps are present in the audio. In other threads on this topic people have described this phenomenon. They have tried using different decks with persistent problems, so it appears to be tape not machine based. So what is iMovie accepting that FCP rejects?
BTW, I tried to use QT Pro (QT->File->New Movie Recording) and was only able to record from the built in iSight of the macbookpro. Can anyone recommend a better capture tool alternative to iMovie? Preferrably freeware?
Rafael Amador
September 14, 2008 at 4:05 am[Lars Fuchs] “But can anyone explain why iMovie will capture a tape from the same PD-170 that FCP can’t capture from?”
You did answer your own question: Because iMovie is not Time Code based.
You can try to set FC to be less demanding about TC requirements. In your Users Preffs, uncheck:
– Abort capture on dropped frames.
– Set “On TC breaks: Warn after capture”.
– Uncheck “Warn when importing non-optimized media”[Lars Fuchs] “BTW, I tried to use QT Pro (QT->File->New Movie Recording) and was only able to record from the built in iSight of the macbookpro”
Go to QT Menu.
You will see Preferences and Quick Times Preferences.
In the first Preferences> Recording, set to AUTOMATIC.
you will be able to capture through FW instead of from the iSight camera.
Cheers,
rafael -
Lars Fuchs
September 14, 2008 at 5:49 pm[Rafael Amador] “You did answer your own question: Because iMovie is not Time Code based.
– Uncheck “Warn when importing non-optimized media””tried these settings, still aborted with the same error. I tried QTpro again ( Thanks for the tip btw), but no joy. Got this error:
Recording stopped because the formate of the source media changed.
Media of different formats cannot be recorded to the same file.So it definitely seems like there are errors in the dv datastream. I would guess that iMovie, as a consumer app, is designed to accept more errors to improve usability for the casual user. It would be nice though, if FCP had a user-variable error threshold; at least one could ingest troublesome footage and decide later what to do with it. After all, some footage is usually better than none!
Interestingly, the audio hits sound different in iMovie. In fcp the tape has repeated momentary lapses of sound – silence. In iMovie there is some sound with digital-sounding noise artifacts. That too suggests to me that iMovie is trying harder to get at least something into the system.
