Activity Forums Apple Final Cut Pro Legacy Can’t capture footage
  • Can’t capture footage
    Posted by Randy Rohde on July 8, 2005 at 7:35 pm
    Sometimes… I have several projects open. I go to a project and want to capture footage. The capture bin is ghosted out and I get an error that a project needs to be open to capture but in fact one is open? Do I need to have ONLY ONE project open in FCP to capture?
    Jerry Hofmann replied 21 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 8, 2005 at 10:33 pm
    No but you do need to set which project file or bin you want to capture to… right click on a bin or on the name column of the project file, and select it to be the “logging” bin… see if that doesn’t clear up your problem.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
