Activity › Forums › Adobe Premiere Pro › Can’t capture DVD data
Posted by Pmg245 on May 1, 2006 at 9:49 pmWe are using Adobe Premier Pro and need to pull video off of a DVD a customer gave us and insert portions of the DVD footage into a project we are doing.
How can I do this using Adobe?
ANY help or advice would be greatly appreciated.
Pmg245 replied 20 years, 3 months ago 5 Members · 5 Replies -
Steven L. gotz
May 1, 2006 at 9:51 pmYou can’t use Adobe for that. You need a DVD ripper. Or, with Premiere Pro 2.0 you can rename the VOB to MPG and get decent results.
Chris Knight
May 2, 2006 at 12:11 amI use a program called Cinematize (by Miraizon – Mac and PC), which converts VOB data in Quicktime files (any codec). Works wonders. A freebie solution would by DVD2AVI (I’ve used this method to convert to uncompressed AVI, and works great – however, you’ll end up with enormous files segmented into 2 gig AVIs with a single WAV file). With both solutions, you can set in and out points, and the process is fairly quick with a decent CPU.
Simon Nuchtern
May 2, 2006 at 12:37 amNot too sure how you are set up – and I am new at APP – but I am doing a big multi media input project and was abe to very successfully capture DVD video by using an external DVD player and inputing through S-video. If you are capturing from a MiniDV or DVCAM deck you can S-Video into the deck and use it as a pass thru to capture. Hope this is what you were looking for.
simon
Pmg245
May 7, 2006 at 4:22 amThank you, thank you, thank you. Thanks to the very timely advice and help we were able to get a project completed and completed on time. I ended up using the DVD2AVI program, turned it into an mpeg and dumped it into our project.
Thanks again, very helpful sight.
