Activity › Forums › Compression Techniques › Can’t cancel a job in batch monitor
Posted by Jonathan Fraser on July 16, 2007 at 8:54 pmSomething went horribly awry during an export out of compressor (the job progress got stuck) , and I’ve decided to re-submit my batch. The problem is that I can neither pause nor cancel the current stuck job in the batch monitor. I can add as many jobs as I want to the queue, but it’s been “cancelling” for about half an hour. Any help is appreciated, thanks for your time.
El Earthbourne replied 14 years, 11 months ago 10 Members · 12 Replies -
Daniel Low
July 17, 2007 at 4:22 pmForce the application to quit – right-click (CTRL-click) on its dock icon
Timebombtim
July 17, 2007 at 9:05 pmwait it out, or foce quit and restart, pick up from the last successful file. best i can do.
peace -
Jonathan Fraser
July 17, 2007 at 9:41 pmThanks for the replies I had tried quitting and restarting (was able to do both) but everytime I opened compressor the job would just start back up again in a frozen state. Funny enough just after I posted I found a clear queue button and was able to re-submit and be on my way. Thanks again for the time though.
John Atkins
August 8, 2007 at 12:34 pmNone of this worked for me. Even turning off the whole computer did not remove the file from the Batch folder. Here’s a solution I found on the Apple support site…and it works.
1. In Finder select go, go to folder
2. Enter: var/spool/qmaster
3. This will find a folder (oddly named with numeral & text). Trash the folders you see INside this folder (mine were called Shared & Jobs
4. In compressor, select the menu item Compressor/reset Background Processing.John.
Robert Gillmer
May 18, 2008 at 5:18 pm[johatk] “2. Enter: var/spool/qmaster”
It’s actually ” /var/spool/qmaster ” and thank you very much, I had the same problem.
Elijah Lynn
July 30, 2008 at 3:33 pmI have two folders in my /var/spool/qmaster/ I guess I will delete contents in both.
Brand new mac pro 8 core with FCS and been having a ton of compressor issues.
Hope Holmesby
July 28, 2009 at 2:27 amwhere did you find a button in batch monitor that says clear queue?
John Atkins
July 28, 2009 at 2:42 am
