Activity Forums VEGAS Pro can’t burn dvd
  • can’t burn dvd
    Posted by Edgar Gillham on September 21, 2013 at 12:22 am
    Vegas movie studio platinum. I create a movie, edit it to 4 parts, join the parts by select/G. delete edit history, go to tools burn disk, read size 2.97 gigs, and press burn disk. All appears normal except the process takes less than one minuet and I only get a video of a few seconds duration. I even get a successful burn message, but only a few seconds of film is recorded. Please tell me I’m making a simple mistake and this is not NSA mischief.
    enjoy yourself, it’s later than you think.
    Edgar Gillham replied 13 years ago 2 Members · 2 Replies
  • Mike Kujbida
    September 21, 2013 at 2:45 pm
    My guess is that you have a small portion of your timeline highlighted, creating a loop region, and also have “Render loop region only” selected in the render options window.
  • Edgar Gillham
    September 21, 2013 at 3:44 pm
    As usual I got a polite and technically competent reply, unfortunately that wasn’t the answer. When I turned on this morning the computer refused to start and went into restore mode. When it finally restarted I tried again and now it seems to be working correctly. thanks again.
