Activity Forums Adobe Encore DVD Can’t Build DVD using Disc Image in Encore CS3
  • Can’t Build DVD using Disc Image in Encore CS3
    Posted by Donovan Werts on August 14, 2008 at 3:42 pm
    Hi, I am using Adobe Encore CS3 and am trying to build a dvd using a “Disc Image” that was created on a previous version of Encore. It works fine on the old version, but when I attempt to build a dvd using the disc image in CS3, the “Build” Key isn’t highlighted (in the “Build Window” and can’t be clicked. I do a “check project” for errors and get two errors: First play not set & Title remote not set. This makes no sense since the disc image contains all that info and should just build with no problems. Can anyone advise on this issue? Thanks in advance, Donovan
    Donovan Werts replied 18 years, 1 month ago 4 Members · 14 Replies
  • 14 Replies
  • Heath Firestone
    August 14, 2008 at 4:00 pm
    If you’ve already created the disk image, you shouldn’t need to use Encore to do the burn.
    Try burning the disk image using whatever disk burning utility you normally use, probably Nero, or Roxio.
    Hope this helps.
  • Donovan Werts
    August 14, 2008 at 4:42 pm
    Hi, thanks for your reply. I normally used the older version of Encore to burn dvds using a disc image. I don’t have another program to burn dvds. Seems strange that the old version could do this simple task and CS3 can’t. Must be a way to simply burn a dvd using disc image in Encore CS3. That option comes up in the build window, just won’t let me click “build”. Thanks again.
  • Joe Bowden
    August 14, 2008 at 5:11 pm
    Have you selected the image file in the Build panel?
  • Donovan Werts
    August 14, 2008 at 5:43 pm
    Yes, I select create using “Disc Image”, then browse for the image file (which worked on the old Encore 1.5). I have a new computer and wanted to use the CS3 Production suite. I suppose I could install the old version, but this is a strange issue to have. Here’s a link to see a screen cap https://www.onlinefilefolder.com/index.php?action=getshare&type=0&user_num=67390&share_id=232225&hash=001c6cfbb1672d8668a51e6055e4e7f4
    Thank you, Donovan
  • Jeff Bellune
    August 14, 2008 at 5:52 pm
    2 things to check:
    1. Is the file that you selected a valid disc image?
    2. Do you have any blank media inserted in the burner?
    Obvious, I know, but it’s odd that the disc size indicator is showing 0 bytes for the size of the disc.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Donovan Werts
    August 14, 2008 at 6:05 pm
    Ah, good questions. I do know that the image file works because I just tested it on my old laptop, with encore 1.5.
    Then I thought you might be on to something, but the zero bytes refers to those used. I do have a Disc in there and the screen cap says 4.7 GB Free…unless I’m reading it wrong. But there’s only one DVD burner and a blank disk is in there.
    I am stumped. Thanks for the ideas though.
  • Jeff Bellune
    August 14, 2008 at 6:12 pm
    What is the file extension on the image file? If it’s .img, change it to .iso. If it’s .iso, then change it .img. See if that helps.
    Otherwise, download the free image burning program called ImgBurn. It’s a great little utility that can burn almost any image at all. If ImgBurn won’t burn your image, then I would suspect something very wrong on your current system.
  • Joe Bowden
    August 14, 2008 at 6:23 pm
    I’ll bet it is the image file extension, and was just going to suggest checking that.
    Encore CS3 expects the extension to be .iso (you can change this in Explorer and it should work correctly).
  • Donovan Werts
    August 14, 2008 at 6:28 pm
    Thank you both. I’ll try that in a bit. I’m supposed to be working lol I appreciate your help, that’s something I never would have tried on my own. Donovan
  • Donovan Werts
    August 14, 2008 at 6:40 pm
    Well, I couldn’t resist and tried the .iso extension with no luck. I can use my old version on my old computer. Strange problem though, thanks again.
