Can’t bring mpeg files to timeline in V6
Posted by Richard Klimesh on August 17, 2009 at 1:39 amVegas 6.0d Build210. I imported a video from a DVD disk and all of the files were saved as .mpg (mpeg). When I try to bring a file to the Vegas timeline I get this error message: “The file format plugin for the specified format was not properly initialized.”
What does this mean and how do I proceed? Thanks.
Richard Klimesh
Mike Kujbida replied 17 years ago 3 Members · 7 Replies -
John Rofrano
August 17, 2009 at 12:29 pmDid you import them with File | Import | DVD Camcorder Disc…? Can you play the MPG files outside of Vegas? It sounds like maybe something got corrupt in your Vegas install. It might be worth re-installing Vegas 6 just to make sure all of the software is installed correctly.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Richard Klimesh
August 17, 2009 at 3:29 pmThis is a DVD I mastered in DVD Architect and had made from a glass master. (I lost the original files so need to get the program files off the DVD).
Yes, I did import the program with File | Import | DVD Camcorder Disc, which took about 3 hours. It didn’t import directly into Vegas but asked to save to a directory, which I did.
No, the files won’t play with any program because each file, like “VTS_06_1 (01)”, is only 1KB, so something is amiss. I’m importing again right now and will see what I get this time.
Richard Klimesh
Mike Kujbida
August 17, 2009 at 3:44 pmRichard, see if the techniques I discussed in the Import VOB Files to Timeline thread will work for you.
Richard Klimesh
August 17, 2009 at 6:05 pmBrilliant, Mike. A quick, simple, elegant solution. Shrink did, however, save the DVD as 47 VOB files, not one big one. But that’s great in this case because I need to work on the files one at a time anyway. Thanks so much.
Richard Klimesh
Mike Kujbida
August 17, 2009 at 6:28 pm“Shrink did, however, save the DVD as 47 VOB files, not one big one”
That’s not supposed to happen.
It should have been one very large VOB file.
I suspect that the step you missed was:Go to Edit -> Preferences – Output Files.
Make sure that “Split VOB files …” is NOT checked.“But that’s great in this case…”
As long as it worked for you, I’m glad 🙂
Richard Klimesh
August 17, 2009 at 6:59 pm“Split VOB Files” definitely was not checked.
Richard Klimesh
Mike Kujbida
August 17, 2009 at 9:45 pmI’m going to blame the gremlins then as I have no idea why that would happen 🙂
