Activity Forums Avid Media Composer CAN”T APPLY ACCELERATION TO 3D animated EFFECT
  • CAN”T APPLY ACCELERATION TO 3D animated EFFECT
    Posted by Romel Mebane on February 21, 2010 at 3:27 pm
    Im trying to apply acceleration to a 3d animated effect.When i go to the effect editor and try to apply the acceleration. Nothing happens, I need help.Does anyone have any ideas.
    Romel Mebane replied 16 years, 6 months ago 2 Members · 4 Replies
  • Grinner Hester
    February 21, 2010 at 6:56 pm
    What do you mean by nothing happens?
    Are you saying the slider doesn’t move or it doesn’t change the curve to S linear?
  • Romel Mebane
    February 21, 2010 at 9:20 pm
    What i mean is that, it doesnt change the curve. When i go to the effect editor and try to apply the acceleration effect. To speed up my animation, it doesn’t work.Every other effect in the effect editior works except for that one. I dont no what it is…..Do you have any suggestions?
  • Grinner Hester
    February 21, 2010 at 11:10 pm
    I think you may be confused about what acceleration does. It won’t speed up your animation, it makes the keyframes smoother transitions from one to the other. To speed up your animation you’ll need to slide some keyframes (alt drag) or shorten the clip the effect is applied to.
  • Romel Mebane
    February 22, 2010 at 11:00 pm
    Thanks for the information.But i have a question to ask you. Im new to avid, only had it a couple of months.I see the learning curve is deep. Will you explain to me how i go about doing that. step by step.See what im trying to do is. I have an 3d animated effect on my time line that im trying to speed up.I have the clip in slow motion, but im trying to speed it up a little bit. To my satisfaction. I would appreciate it if you can assist me in anyway.
