Activity Forums Adobe After Effects Expressions can’t adjust color controller expression?
  • can’t adjust color controller expression?
    Posted by Don Mick on March 15, 2021 at 9:08 pm
    i have a youtube template pack where i’m trying to change the color. however, when i adjust it, the color doesn’t actually change. i suspect it has something to do with the expression. can anyone please help? Thanks!
    Don Mick replied 5 years, 6 months ago 3 Members · 3 Replies
  • Fabrice Leconte
    March 15, 2021 at 9:15 pm
    Try to select the layer and press E key twice to see expressions.
    Then you can edit or remove expressions
    Or you can click on this icon to enable/disable expression
  • Dan Ebberts
    March 15, 2021 at 9:17 pm
    The expression indicates the color is coming from layer “CONTROLS” in comp “InfoBar_v10”. It looks like the comp you’re in is “MainComp_InfoBar_v10”.
  • Don Mick
    March 15, 2021 at 9:44 pm
    thanks, everyone! this helped me find out that i was in the wrong comp when making the changes.
