Activity Forums Adobe After Effects Can’t add stroke to Mocha shape layer
  • Can’t add stroke to Mocha shape layer
    Posted by Renato Soares on October 1, 2018 at 10:50 pm
    So, I generated a layer tracking on mocha ae and imported into AE, applied to my layer and everything is fine. However when I try to add a stroke (generate>stroke) the stroke simply does not appear.
    I guess it’s because it’s not a Mask per say, but that’s the only way I found on to copy the paths from mocha.
    Ross Shain replied 7 years, 11 months ago 2 Members · 2 Replies
  • Renato Soares
    October 1, 2018 at 10:57 pm
    I just noticed on a youtube tutorial that when they paste the shape data it turns into a Mask not a Layer like mine. I tried to paste it into a solid or even inside a mask but didnt work
  • Ross Shain
    October 2, 2018 at 7:08 pm
    If you want to apply effects such as stroke to a Mocha generated roto shape, you need to “paste as an AE mask”.
    If you are running Mocha AE and have a roto shape on the clipboard, you will see 2 different paste options under edit menu:
    Paste (pastes Mocha as Mocha shape plug-in – good for variable edge feathering)
    Paste AE Mask – converts Mocha shape to AE mask
    Ross Shain
    Boris FX / Imagineer Systems
    https://borisfx.com/products/mocha/
