Can’t add stroke to a composition containing masks
Hello!
I have cut several masks and precomposed them. Now I want to add a stroke effect to all the masks in the composition, but the effect doesn’t seem to change anything, when I apply it to the comp. It works on seperate layers withtin the comp, but not on the whole thing. I could add seperate effects on each layer, but there are like 80 of them, and it would be inconvenient :/
I also tried to use an adjustement layer within the comp, but this doen’t work either.Is there anything I can do to make this thing work?
Thanks in advance!
