Activity › Forums › VEGAS Pro › Can’t add .mpg to video track – high pressure matter
  • Can’t add .mpg to video track – high pressure matter
    Posted by Ricardo Moreno on August 19, 2008 at 2:25 pm
    First let me give you context. My wife had the brilliant idea of making a video for her 80 year old moms bday with all 6 sisters and grand kids recording videos which I am suppose to make into one dvd to play at her party. I spent 1.5 hours trying to get the first 30 sec .mpg on the timeline… I have 3 weeks and at least 14 clips headed in my direction … mercy!
    So, back to my dilemma with this mpg file. I downloaded a program to convert to .avi and found that only the audio portion of the clip would load(half way there.. lol. The clip plays on Windows Media player. I read the post before mine about the codecs. Since it is likely I will be getting clips recorded on dif devices and such, I I assume I will need to standardize all of them to a common format or codec(which one and with what software?) in order to then work the clips into the timeline. So a few questions:
    1. How to I identify the codec of the .mpg file I am having trouble with or any others for that matter. Properties does not seem to tell me enough.
    2. Once I have done that, what steps would I take to convert it to a more common codec/format and which would be the easiest to work with.
    3. Am I going about this the right way.. ? any advice would be truly appreciatted.
    Ricardo Moreno replied 18 years, 1 month ago 2 Members · 3 Replies
  • Douglas Spotted eagle
    August 19, 2008 at 3:04 pm
    1-Upgrade to Vegas 8, it’ll read the mpeg from the camera directly
    2-convert to a standard DV avi format vs something like Xvid or DviX.
    Either solution will save you lots of grief and potentially give you better quality.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Ricardo Moreno
    August 19, 2008 at 4:51 pm
    My apologies .. I should have indicated I am working with Vegas Movie Studio Platinum 8.0b (Build 122). I do not know if the clips were shot with a camcorder, phone or what… I did find info on codecs.com on programs that would help me identify the codec it is using… but still wondering if I need to use the same codec for all clips or if the rendering when producing th dvd will make it all work…
  • Ricardo Moreno
    August 20, 2008 at 12:07 am
    OK this is how this clip is identified… is it obvious why Vegas will not work with it? If so what is needed?
    General
    Complete name : C:\Documents and Settings\Ricardo\Desktop\Kristin’s Video.MPG
    Format : MPEG-PS
    File size : 4.24 MiB
    Duration : 12s 160ms
    Overall bit rate : 2926 Kbps
    Video
    Format : MPEG Video
    Format version : Version 1
    Format settings, Matrix : Standard
    Bit rate mode : Variable
    Bit rate : 2659 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4/3
    Frame rate : 25.000 fps
    Scan type : Progressive
