Activity Forums VEGAS Pro Can’t add more than 1 effect
  • Can’t add more than 1 effect
    Posted by Avanis Apollon on September 12, 2017 at 11:34 pm
    Hi, I’m currently using Vegas Pro 13 and I had a little problem that holds me back from making my video.
    I’ve downloaded a pack with some effects and I successfully installed them with the Preset Manager, when I tried adding an effect, it worked, but when I tried to add a second effect in the same clip, the first effect was replaced with the new one, I can’t add more than 1 effect without getting the first effect replaced.
    This only happens with the pack that I downloaded, when I add the default effects of Sony Vegas, I can add more than one without any problems, but with the pack that I downloaded, it doesn’t work, I also tried another pack, but I had the same problem. This how my panel looks like: https://prnt.sc/gkfx2v I click on 1 effect, I add it, I click on another effect, click on ADD, it replaces the other one that I added before with this one.
    Any help would be appreciated, thanks!
    Edward Troxel replied 3 years, 9 months ago 3 Members · 2 Replies
  • Rick Akker
    October 12, 2022 at 10:43 pm
    Hello.
    Did you find the answer, I m in the same situation like you.
    I cannot add more than one fx..
    Any answers?
  • Edward Troxel
    November 10, 2022 at 6:24 pm
    When you add a “Package”, you replace all effects with the new set of effects.
    If you add the effects individually, you should be able to add them all.
