Activity Forums Adobe Encore DVD Can’t add audio to timeline
  • Can’t add audio to timeline
    Posted by Warik on April 26, 2005 at 11:38 am
    Hi I am a new user to Encore, so this is probably a stupid question: So far I have used Premiere for my mpeg encoding. Now that I have imported both the audio (wav) and video (M2v) files into Encore I want them to play together. However I can’t add an audio track to the timeline I created for the video. The timeline pull down menu has this option greyed out. What am I doing wrong?
    Warik
    Warik replied 21 years, 5 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    April 26, 2005 at 4:22 pm
    What version of Encore do you have?
    Make sure you have the Timeline window active when you try to choose from the Timeline menu.
    Also, by default your timeline should already have an audio track in it, so you can just drag your audio file down into it.
  • Warik
    April 26, 2005 at 10:24 pm
    Thanks for that.
    As I thought, it was my own stupid fault. I only had the timeline library open, not the actual timeline itself. D’oh!
