Activity › Forums › Boris FX Particle Illusion › Can’t add any media to a layer
  • Can’t add any media to a layer
    Posted by Alan Greenwood on October 19, 2010 at 12:05 am
    Hi
    Just installed PI and can’t add any type of media (AVI or image) to any layer. Double clicking the grey icon opens the standard Open File dialog where I browse to the file I want to add. Clicking the file to select it crashes PI and I get the Windows ‘This program has stopped responding’ etc etc error message and PI closes with error report sent to MS.
    I’ve tried several different file types all with the same result. From my Windows error logs, the below is what I have. Any help will be much appreciated as I can’t start using the app until I can load in external clips
    Cheers
    Alan
    Product
    particleIllusion
    Problem
    Stopped working
    Date
    19/10/2010 00:44
    Status
    Report Sent
    Problem signature
    Problem Event Name: APPCRASH
    Application Name: particleIllusion.exe
    Application Version: 3.0.5.0
    Application Timestamp: 4cacee21
    Fault Module Name: ntdll.dll
    Fault Module Version: 6.0.6002.18005
    Fault Module Timestamp: 49e03821
    Exception Code: c015000f
    Exception Offset: 00075cbb
    OS Version: 6.0.6002.2.2.0.256.1
    Locale ID: 2057
    Additional Information 1: 4f8e
    Additional Information 2: db46a8e8a518198adee38ef6e6a13606
    Additional Information 3: 4974
    Additional Information 4: cf8ff2423cd2e1091bffd9d8baf3d1b6
    Extra information about the problem
    Bucket ID: 2068576074
    Alan Lorence replied 15 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Alan Lorence
    October 19, 2010 at 1:35 pm
    This is an issue with 3.0.5 on Win 7 — a patch will be released probably later today or tomorrow morning.
    Note that 3.0.5 has limited release yet — we didn’t add it to the “AutoUpdate” data yet, but will sometime soon. So everybody with 3.0.4 will be able to update to 3.0.5 sometime in the near future. It contains bug fixes and a new licensing (activation) system, but no new features. So you’re not missing out on anything too exciting if you’re using 3.0.4.
    Alan.
    http://www.wondertouch.com
  • Alan Greenwood
    October 19, 2010 at 1:51 pm
    Hi
    Thanks for your reply and look forward to getting the patch.
    >>we didn’t add it to the “AutoUpdate” data yet<< Just as a FYI - I ended up with 3.0.5 as it was in the AutoUpdate list as an available update, so consequently went ahead and installed it 😉
    Cheers
    Alan
  • Alan Lorence
    October 19, 2010 at 3:34 pm
    I think what probably happened was you got 3.0.5 to start with (that’s what you got when you purchased), then saw my test update which was labeled as 3.0.5.1 but was actually just 3.0.5 again. This test update was only on the server for a short time.
    So you installed it but really still have 3.0.5. You can verify that this happened by checking your “about” dialog. If it says “3.0.5 test”, that’s what you have. It’s exactly the same code as 3.0.5 except for that “about” string.
    When the real 3.0.5.1 is released you’ll see that listed, and after the update the version string will actually be 3.0.5.1.
    Alan.
  • Alan Greenwood
    October 20, 2010 at 8:17 pm
    I’ve installed the update and now have version 3.0.5.1
    PI no longer hangs when trying to import media to a layer, but I now get
    Attempted an unsupported operation
    error message no matter what media type I try and import
  • Stephane Parenton
    October 21, 2010 at 7:05 am
    Hello Alan,
    Where did you find the download for 3.0.5.1 ? i experience the same problem with my Win7/64 and i’d like to try the newest version (as you did 😉 ). Can you post the link you’ve used ? TIA
    Stephane
  • Alan Greenwood
    October 21, 2010 at 12:17 pm
    Hi
    It was showing as an available update from Help–>Check for updates
  • Alan Lorence
    October 21, 2010 at 2:44 pm
    If you’re running 3.0.5 (Win) already, you can “check for updates” to get the 3.0.5.1 update.
    If you’re running 3.0.4a or lower, you shouldn’t see the 3.0.5.1 update available with good reason: it will break your activation. 3.0.4 shouldn’t have any of the problems that 3.0.5 does with Windows 7.
    If you’re running a very old version (like 3.0.2) then the 3.0.5.1 update might show up in the AutoUpdater due to a bug in 3.0.2. If you do see it, DO NOT UPDATE! The 3.0.5.1 update is only for 3.0.5.
    Alan.
