Activity Forums Adobe Premiere Pro Cant add a tick box property to metadata :-(
  • Cant add a tick box property to metadata :-(
    Posted by David Honan on April 23, 2015 at 10:25 am
    Hi from foggy and freezing York UK 🙁
    https://i216.photobucket.com/albums/cc53/zymurgy_bucket/no-tick-box-category_zpssu0cdu0u.jpg
    The above link illustrates my problem but here goes… Thanks to previous advice i now know how to create
    new meta data categories for the project pane. Now whilst i can create new columns I notice there are 4 options:
    Integer
    Real
    Text
    Boolean
    But what about a tick box category like the off the shelf “Good” property? Thing is I need to create a “Bad” meta display property that can be ticked for the project pane, is this possible, thing is Ive tried all 4 options and no tick box appears,
    Grazie mille,
    David
    David Honan replied 11 years, 4 months ago 2 Members · 2 Replies
  • Alex Udell
    April 23, 2015 at 10:52 am
    Hi David…
    how about?
    name the category bad…
    then use boolean as the method…
    boolean is true or false…so in your case…it’s either bad or it isn’t…
    that work?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • David Honan
    April 25, 2015 at 10:34 am
    Yes thank you Alex that work perfectly 🙂 Grazie mille!
