Activity Forums Adobe Premiere Pro Can’t activate recorder error. HD
  • Can’t activate recorder error. HD
    Posted by Danny Winn on May 25, 2009 at 5:01 pm
    I HAVE read the previous threads and the Adobe site suggestions to no avail.
    All the sudden when I try capturing HD from my Canon XH A1s with PPro CS4 I get this error message “Can’t activate recorder, try resetting Camera”.
    It wasn’t doing this last week and I haven’t changed any settings.
    So multiple times in different sequences I tried turning re-setting & turning the cam off, restarting the computer, checked all my internal cam settings, unplugged the firewire cable.
    And yes, I read all of the suggestions on the Adobe site.
    I can capture with a cheap 80 dollar program with the same firewire connection but I don’t like to with that because I can’t refine the capture settings like in PPro.
    So If any of you know or have a guess on whats going on here I’d appreciate any input.
    I did notice that when I turn the camera on it doesn’t always get detected by windows other than the first time, should it?
    Eddie Lotter replied 17 years, 3 months ago 2 Members · 3 Replies
  • Eddie Lotter
    May 25, 2009 at 10:17 pm
    [Danny Winn] “should it?”
    Absolutely, yes.
    If you create a new project can you capture using the camcorder?
    Cheers
    Eddie
  • Danny Winn
    May 25, 2009 at 10:46 pm
    Thanks Eddie,
    Even though I was setting up a new project and selecting HDV 108024p for my capture setting, the problem I know now was that it was defaulting back to “DV” in the “Capture Settings” Tab when I attempted to capture, I never looked there because the error message makes it sound like your camera is the problem. I knew I was selecting HDV 108024P in the initial project setups (I did about 12 different project setups before I caught it).
    The error message should say “Check HDV/DV Capture settings”. Haha
    Seems to work now but I will always check that when capturing now.
    Thanks for your response.
  • Eddie Lotter
    May 26, 2009 at 1:38 pm
    You’re welcome.
    I’m glad you figured it out.
    Happy editing. 🙂
    Cheers
    Eddie
