Activity Forums Blackmagic Design Can’t Activate Recorder
  • Can’t Activate Recorder
    Posted by Howpix on February 11, 2006 at 8:43 pm
    I have a BMD SP card on a SuperMicro P4SCT+II with an Nvidia Quadro FX 700. With the BM drivers 5.4 (and 5.4.2) uninstalled, DV capture works fine in PPro 2.0. With the drivers installed I get the old “Can’t Activate Recorder. Try Resetting Camera.” error message when trying to capture.
    Works without BMD drivers doesn’t work with BMD drivers. I’m a little dense but I think that conclusively points to the BMD drivers as the source of the problem.
    Anyone agree?
    S. Howard
    Kristian Lam replied 20 years, 7 months ago 5 Members · 4 Replies
  • Shane Chadder
    February 12, 2006 at 2:44 am
    I agree. Our systems do the same thing.
    BM support told me they were trying to track it down with Adobe. You might want to send BM support a note so they know who is having a problem.
    Shane
  • Theoutsider
    February 15, 2006 at 1:06 am
    Temporary solution is to rename your decklink.dll. This way you don’t have to uninstall or reinstall your BM drivers when you want to capture.
  • Greg J. winter
    February 16, 2006 at 1:52 am
    I get the same problem with PPRO 2.0 with DV capture using regular DV settings. Output does not work either to the DV device. Once I remove the BMD drivers from this directory – C:\Program Files\Adobe\Adobe Premiere Pro 2.0\Plug-ins\en_US —> restart PPRO, everything works as normal.
  • Kristian Lam
    February 16, 2006 at 4:51 am
    Thanks for the report. We’re investigating this and I’ll keep you all updated.
    regards
    Kristian
    Blackmagic Design
